After I got done dinkin' around with Jakes XR, I decided to start on the t-case swap. Took the passenger seat out, took the doghouses out. Well, since I was there, decided to take the trans/transfer shaft out, and the front , rear driveshafts, speedo cable, 1- R link, e-brake stuff. Took a look, well, only 10 bolts left, Might as well take it out! I have to say, out was a dream. Used a 1 1/2 x4 channel over the doors, and out it came. The drivers side mount on the air shift was different from the one in the truck, thanks to having a great set of stud removers! Swapped the mounts, decided the way I had it slung on the way out just wasn't good enough. Anchored the chain to the LH, rear top plate instead of the LH front, MISTAKE! Lifted it great, but went onto the chassis really bad. Took an hour to wrestle the pig back into the place it needed to be.....NEVER 2nd guess yourself! Got it up, all the mounts are tight. All that's needed is to put the shafts back up, speedo cable, interior and air plumbing. All in all, it was lots easier than I thought, went a bit smoother than I thought. I wanna thank all that offered help, but, I had the day off and things just happened!
