Alcohol and marvel mystery oil mix
CHIEFSONN
It has been mentioned that in one thread that it is good to add this mixture of alcohol/marvel mystery oil into the intake of the air compressor to help prevent the air line from freeze during cold /freezing temperatures. the mixture was mentioned that you would mix the two to get a pink color,but how much was to be added was not mentioned.can some one that has used this in there system let me know, thank you for your replys.
Wayne
doghead
4 Star General /Moderator
1,177
NY
In a shop system or vehicle?
If vehicle, which one?
Are you having problems now?
CHIEFSONN
I will be spraying it (alcohol/marvel mystery oil ) into the intake the air compressor that is in my M35A2 Deuce. No I have not had any problems I just want to take a safety precaution before I make the 170 mile trip. I will also be adding air tool lubricant into the air pack. thanks
