- 1,694
- 1,757
- 113
- Nova Laboratories, WA
I was reviewing the diagram of the parking/turn lamps, and it seems that the park lamps should be steady, even if the turn signal is on. However, on my m1009, my corner marking lamps alternate with the front turn signal when the parking lamps are on.
I haven't seen any abnormal splices, but my LED bulbs ARE finding a ground path through the high (turn) line, meaning my parking lamps won't work if the turn line is connected (even if it's not energized).... Even running a ground directly to the battery. Taking the connector out of the circuit and the wiring works properly (high/low/gnd).
Works fine on incandescent....
Short of running all new wires, just to run LED turn signals, anyone got some insight?
Am I correct in that the side marker isn't supposed to alternate? If it is, I have a feeling that things will be more difficult than I want...
