- 10,350
- 75
- 48
- Meadows of Dan, Virginia
Rizzo, coking as I understand it , builds up over time and comes from starting on cold WVO, which may leave a residue. WVO is also acid and leaving it in the system when the engine isn't used may cause other problems in the long run.
With a two-tank system, only regular diesel is left in the system when the truck is not used.
In the summer I have noticed that the fuel temperature will build up as you drive, I have seen 125°F on my fuel temp gauge and that's without heating the fuel. I don't have to use the haeter much on a drive when it's warm out. The return flow back into the tank is about 2 to 3 quarts/minute so it doesn't take long for all to have cycled through and been heated by the IP and injectors.
Gary, a 50-50 fresh VO mix with diesel should be perfect.
