badblack01gt
- 0
- 1
- Belpre, Ohio
It looked looked like it was moving along really well when you passed me and sounded great! It gave me duece fever all over again
Note: If you are adding an
airbrake endorsement to a CDL
license, a full skills test will be required in a vehicle equipped
with air brakes.
FYI Air brakes are a restriction on a CDL and NOT an endorsement.
FMC 383.95The problem is, each state he drives through, may have their own set of rules and terms.
Seems like we now have 11 different(and probably incorrect) replys.
That would be correct. The only way I can understand it is, if there is anyway that air is used in the braking system, then you need the air brake endorsement. I do not even think a Historic Tag would over ride this fact.FMC 383.95
Subpart F - Vehicle groups and endorsements
.§ 383.95Restrictions. (a) Air brake. (1) If an applicant either fails the air brake component of the knowledge test, or performs the skills test in a vehicle not equipped with air brakes, the State must indicate on the CLP or CDL, if issued, that the person is restricted from operating a CMV equipped with any type of air brakes. (2) For the purposes of the skills test and the restriction, air brakes include any braking system operating fully or partially on the air brake principle. (b) Full air brake. (1) If an applicant performs the skills test in a vehicle equipped with air over hydraulic brakes, the State must indicate on the CDL, if issued, that the person is restricted from operating a CMV equipped with any braking system operating fully on the air brake principle. (2) For the purposes of the skills test and the restriction, air over hydraulic brakes includes any braking system operating partially on the air brake and partially on the hydraulic brake principle.
FMCR spells it all out, even the air over hydraulic.
Not my truck, sadly!It looked looked like it was moving along really well when you passed me and sounded great! It gave me duece fever all over again
