Any interest on a deep dive into Cat C12 oil systems? Specifically into Oil Pressure?
IridiumRed
57
NW MO, north of KC
Is there any interest in a deep dive into Cat C12 oil systems, specifically oil flow / oil pressure?
I got an MTVR about 8 months ago, and its oil pressure seemed a bit low to me, and also a bit "odd"... i work w commercial trucks everyday (mostly garbage trucks in the 30-40k GVWR size range), and the oil pressure readings on the C12 didnt quite make sense to me (seemed low overall, but also didnt behave the way im used to seeing when it comes to oil press vs rpm, and also with changing engine temps)
This MTVR is my own personal truck, and is mostly a playtoy for me (am working on making it essentially a huge pickup for myself, not driven everyday but probably 2 or 3 times a week, often to commute)
Anyways, i took a pretty deep dive into how the oil systems work on these trucks, to either fix the oil pressure on my truck OR understand how it works and one way or another get comfortable w the oil system. This stuff is still pretty fresh in my head, i could write out a fairly detailed report on it, including what all the oil bypass valves are & how they work (there are 4 valves in the oil filter base, each w its own function... each of which can be their own problem)
Is there any interest out there in reading that? I wouldnt be surprisef if this turn into 10 to 20 pages. With me, there is no "short story", i tend to get very detailed (possibly excessively so).
I wouldnt say im an "expert" on these systems, but i think ive put together more of an explanation on how/why these systems work then ive seen anywhere else, at least gathered together in one place. Currently its just in my head, so i need to do this soon before it starts getting stale / forgotten. It would be a little work to do, but be kinda enjoyable for me to work on when i need a break from other stuff. If i knew that a few of you would read it, enjoy it, that would prob be the motivation needed for me to start working on it.... so let me know :)
IridiumRed
57
NW MO, north of KC
Wanted to add that I'm particularly interested in hearing from those of you who have youtube channels / otherwise post a lot of content RE MTVRs... since i've watched / utilized a lot of that myself, been very handy for me, I'd like to give back as i can
19,765
I would like to see what you have to share.
I have a MK23 and it sure can't hurt to learn more about it...
IridiumRed
57
NW MO, north of KC
Ill probably put something together. Partly for mysrlf, in case i have issues down the road and have to revisit this subject, be nice to have summary document. Prob 70 to 80% of what ill present wlll be info from cat's factory documentation, but condensed into one place. The cat onfo itself is spread across 3 or 4 sources and multiple pages, which makes it hard to see the big picture sometimes.
Anyways, ill prob do.something soon, since things are still fresh in my mind.
A lot of people might say i over analyze things sometimes, and maybe thats true... sometimes. But i get a lot of pleasure out of digging into something and really understanding it, and then i get comfort out of fixing something to the point where i dont worry about it anymore and just kinda forget about it... which is why i need to do this soon... before i forget :)
IridiumRed
57
NW MO, north of KC
I havent forgotten about this. Its still in mind, ill be doing something on it. Gotten distracted by some work trucks breaking down, having to scrsmble to get them fixed (all good now).
Also, i have been working on some things that are related to this (oil prsssure, flow), should be done soon. This stuff will give me some interesting data and just be cool to share.
What ive been setting up is -
Putting in another oil pressure gauge (this time a full sweep electrical gauge, reading from the oil filter base area, dont know if the pickup will be any more accurate then the stock oil pressure pickup, but the gauge at least probably will be vs its stock counterpart, and will be essier to resd/give more precise reading).
Bypass oil filter. Cat C12s can run a bypass filter (mounted to the oil filter base, right next to the primary oil filter). On the MTVRs tho, packaging is tight, the main oil filter is mounted remotely, and theres not enough room for the bypass filter, and dven if there was room it would be difficult to get to.
So, ive figured out way to run a bypass filter (same filter as what cat would normally run) but mounted remotely. Took a while but figured out reasonably priced remote mount that is good quality (fleetguard unit, that is spec'd by cummind for various OE applications i think), and how to hook it into system.
Also, and for me as a motor geek, the coolest thing - im setting up a couple of oil accumulators to act as prelubers. The basics of an accumulator - have a tube with a sealed piston in it, on one side of piston you have sealed air, the other side has oil in it. Have a line from that oil side to the engines oil supply system, with shutoff valve in between accumulator and engine. Air side is adjustable for pressure. If the pressure in the accumulator is grester than oil system presdure, and accumulator is full of oil, then oil will flow to the engine if valve is opened (this is the core of the "preluber" concept... can open valve right before engine is started, which gives quick dhot of pressurized oil to oil system, eliminating dry starts.
While engine is running, if oil system pressure is greater than the air pressure, the oil will flow back into the accumulator, refilling it. And vice versa... can use accumulator to send a few seconds of oil flow/pressure to engine if it has momentary losses in oil pressure. This is a common thing w race cars that have oil system issues, where maybe the oil pickup is on one side of engine and they have long turns on a track that pulls oil away from pickup. Or maybe its a front to back issue, maybr have oil pickup at the back, and hard braking runs all the oil forward. Bottom line if there are places where for 5, 10 seconds an engine is running low/no oil presdure, an accumulator can fill in that gap, provide flow/pressure for that narrow window until system recovers normal operations...
Anyways, am in process of setting up the above on my truck. Hopefully be done soon... and ill be sharing details on it when i do. Its giving me some good info / ideas on the oil system as i do it / use it.
Running a preluber is just something ive wanted to do for a long time, this just gives me an excuse/opportunity to do it. Its more in the realm of "want" than "need"... but this truck is my toy, so perfect time to do it. And eliminating dry starts is a good thing. Esp on this nice and expensive of an engine. Having bypass filter will be nice too, that keeps oil a lit cleaner, reduces wear particles and hence wear. Keeps oil good for a lot longer too. Again, just stuff i want to do :) ill share about that setup + oil system info on c12s in general when ive got it figuref out a bit more. Am getting close :)
flyfishtrailer
1,041
Cool, CA
I don't have a truck that big (M1078 with CAT 3116), but it is always good to learn more. Even if there is not a ton of folks asking questions now, preserving your knowledge on a thread may help folks down the road as more of these trucks hit the civilian market.
