dc3coyote
- 19
- 0
- Chattanooga TN
I dont think the side of the road needed plowing. I guess that is why you should always have someone with you to hold your beer, while your plowing.
Plowing some parking lots, mostly big developments, one pass each way, done.. Yes, built it, took alittle time to design. Like a month straigh, truck and plow. If you would drive it, you would understand, "kick *zz" being the only way to describe it.Power V That will work with one pass. Did you build it?
That is not a bad idea, I didn't even think about using a pneumatic actuator. Might be problematic with freezing temps though.Drove m35a2 with plow in service. Clamped onto front axle and was supported on lifting points on front bumper after shackles were removed. Used 12v meyer pump wired to one battery on truck. An air operated hoist would be practical on m35 or m 809 series as they have air brakes.
