dma251
- 15
- 18
- Arlington, Washington
First is obviously the left side case of my winch - it started leaking after I bumped the lever down and did the "Oh Crap!" move of reeling in until I sheared the aluminum pin. No damage visible to the bumper or winch otherwise. I didn't see any cracks or bent metal.
The next is a nasty littl eleak from the top of my transmission where the shifter comes out. Ever seen that?
Last are some shots of what may just be a leak from the pinion seal on the top of the front diff, but it sure is pumping out a lot.
I guess the best way is to pressure wash all the oil/lube off and go from there. Just wondering if anything real obvious or typical jumps out at anyone.
I'm getting ready to order a bunch of PM parts to address all of these leaks, so I want to make sure I don't forget anything.
