Are market lights required to be legal?
ramdough
1,729
Austin, Texas
Do you have to have them day one or is that a nice to have. I imagine temporary boxes don’t need them, but when is it a requirement?
ramdough
1,729
Austin, Texas
Was referring to the box markers. Not the cab in case anyone is wondering?
2,635
In Ca, yes. Amber on the top front and each lower front corner, red on the top rear and the lower rear corners. Container trailers, yes, not the box. and I believe that red/white reflective tape is a requirment too.
For your viewing pleasure....
ramdough
1,729
Austin, Texas
From that link, it looks like no extra lights than are already on the truck are required. Did I read that wrong? I would be under 30 feet long.
19,646
Considering that you are in Texas, here is the law.
You might be well advised to consider driving in other states might have other rules and DOT Federal rules might be a good source of information. See Attached.
chucky
18,858
TN .
Yea like he said the permantly mounted box front top corners in yellow and atleast one top/bottom center side of trailer yellow and red on top and bottom all 4 corners seen from side and rear ! Container haulers just have the tote trailers lite up the container is cargo not permantly mounted so no lights !
ckouba
1,703
Oregon
I have read on here and other places that states have reciprocity agreements, and if something is legally titled in one state, regardless of the rules of the state being visited, the registration, etc... is honored by the hosting state.
The easy example is front plates. Not all states require them, and if yours doesn't but you visit mine which does, you won't get a ticket.
The underlying premise is that you're legal in your home state though, so do your homework on that end, and it's generally a good thing to be compliant and consistent with federal DOT regs as well.
