Atomic Annie and Two Prime Movers
avc8130
Sussex, NJ
I was doing some research, and I realized I've actually visited 5 of the 8 known survivors on display around the US. I guess I need to go out and "collect" the other 3 some day.
ac
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
But does the 4.2 million grains of projectile weight equate to 58.3 million ft/lbs of muzzle energy, or should you figure propellant weight to calculate muzzle energy? Or do you factor both. I'm a reloading dummy.
The weight of the propellant has nothing to do with the calculation of the energy. You are only concerned with the velocity at which the projectile is leaving the muzzle and the weight of the projectile. The only other factor is the constant of gravity. You are looking at how much energy it takes to move that 600 Lb projectile up to 2500 Feet per second.
The numbers are hard to imagine which makes this topic real interesting. To put it into a perspective I can understand better, would that be equal to lifting 4,859 deuces?
To put it in a more common perspective related to shooting. Your standard 5.56x45 NATO round from your AR-15 or M-16 has a muzzle energy of 1250 Ft/Lb, your standard 7.62x51 NATO (.30 cal) round has a muzzle energy of 2550 Ft/Lb. Bear in mind that the muzzle energy is directly related to felt recoil (with offsets for muzzle brakes, recoil pads and the like).
jwaller
19
Columbia, SC
The 5ton truck looks like the honest john missile system. Seco has a number of these trucks in their yard being cut up for parts. They couldn't use them as they were so they were all being parted out. Neat trucks but useless in the civi world.
gunboy1656
22
Beaver Falls, PA
There is a thread on here that shows a pic of a rear prime mover for the 280MM gun for sale. Be warned need some deep pockets.
It also has the drive train listed.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
SECO has Honest John's? Where? I thought they had to be totally destroyed before release?
11Echo
92
CT W. R.
At Sam Winers ...
VPed
294
Clint, TX
It's been years (decades) since I was out by YPG. They added the rocket launcher since then.
303rdGLCM NM
Los Lunas, NM
The gun and movers were at the Atomic Museum on Kirtland AFB when I got there in 1989 and looked just as good then. The Museum moved off base to make access easier for civilians to get to with all the added security in the 90's. The museum is a great way to spend an afternoon.
