AWOLs 1997 M1097A2 Build
Awol
396
MA
Finally able to get it in the sun, after seemingly endless rain. Looks pretty good. Still need to cut and buff, but I'd like the paint to be a little harder before doing it.
Also had the original hood and tailgate markings remade, and will go on the truck along with all the other original markings.
Awol
396
MA
Had a little whoopsie while buffing the hood. Burned the clear a little, right smack dab in the middle of the hood. Not a huge deal, just gotta sand it back and blend in some color.
TOBASH
3,219
Brooklyn, NY
Awol
396
MA
Seems like you either need to use lighter grit and sand a little less OR paint thicker coats.
Been there. Done that.
I was in an awkward spot with the buffer, and stood it too much on its edge and burned the clear real good. Getting to the center of the hood on these things isn't as easy as you'd think lol
Just got done spraying the clear and blending it with UPOL #9 blending agent. Now I just gotta let it harden up, then a quick cut and buff on the repair and it'll be good.
Awol
396
MA
Ran a 5% eyebrow on the windshields today. It's about 4" long. They sit up higher on the window than the sun visors do when they're down. Looks damn good imo.
I need to get a better pic of it outside, but here's one right after I did them. 20240503_162251.jpg
Awol
396
MA
Installed a Black Dog Customs cargo divider/ rear curtain sealer. Fit is decent. It's a little short on the driver side, so you need to seal the ends with silicone or seam sealer. I used some black seam sealer I had laying around.
You gotta drill a bunch of 3/16 holes, and make sure to not go too deep or you'll puncture the fuel tank. I'd recommend using a drill bit stop.
Awol
396
MA
Little update:
I've taken the truck on a few short trips, but today I took it on a 70 mile journey through back roads and farmland. It performed flawlessly! Cruises at 65mph no problem, doesn't get hot, and doesn't seem to have any weird shimmy or shakes. It's pretty cool cruising down the road knowing that this truck was sitting in a lot down in GA only a few months ago. Now it's cruising around New England.
Next up is the stereo. I need to lay it out and see where I want to put stuff. The Bluetooth speaker I'm currently using isn't gonna cut it lol
Pics don't want to upload right now, but I took some.
