- 1,128
- 113
- Athens, Ga.
Make sure you let the RTV cure for a minimum of 24 hours before moving the truck.Thanks for the help. This time I think I will just use rtv and leave the cork out of the equation and see what happens.Might get lucky.
I might be misunderstanding you guys,I am looking at the TM,where is this cork plug,
or do you mean cork gasket?
http://www.steelsoldiers.com/showthread.php?73686-Oil-bath-bearingsIs there a way to let the rear bearings be dif oil bathed instead of just grease?
http://www.steelsoldiers.com/showthread.php?56839-Convert-to-Oil-Bath
http://www.steelsoldiers.com/showthread.php?89082-Axle-Seal-Hub-Thoughts
