Axle Leaks
1,128
aspann, check this out:
http://www.steelsoldiers.com/deuce/5935-leaking-axle-seal-repair.html
I can't remember which TM it is, but if you've ever done a wheel bearing or a 3/4-1ton truck with a full floating rearend, it's the same.
You just need to clean everything up, pack the bearings and put the right amount of preload on the bearings. I do them by feel, your mileage may vary.
I believe there is an oooooooold thread here written by member "h1crwchf" that detailed axle bearing preload with a LOT of detail. Try finding it, if you can't, I will look for it.
Don't be scared of it, it's an easy job. Heck, my dog helped me do my last pair.
aspann
Elba/Al
Thanks Clintl, the grease we plan to use is G403, GAA, 9150-00-190-0907, Mil G10924c. Would this grease work?
Found h1crwchf and he has some good information. I printed his info and will go by it.
