I'm not sure I know what you mean about a washer. I really have not gotten into the A2 that far....thank GOD.
From my understanding, which is limited to disassembly and reassembly of the T-138 out of my M817 (not a T113, the center gear shaft wedges at a low angle (even lower in the T-113, forcing the gears apart, breaking their shaft mounts in the case. I could see how that could happen, even in the T-138 under extreme reversing torque.
Not possible. I drive too far onto my soft dirt when filling a hole (backing onto the pile) and need it in muck for both backing and then especially forward when loaded. Loads of the muck are a one shot deal, like working on top of a bowl of jello. If my fuel was turned up some, it might do better getting out. If I'm not in low range to begin with backing in, getting it into low can be difficult with a load.How about just not using low in reverse? With the 10:1 reverse trans ratio, I don't see low + reverse being needed.
Has this ever been done? All of us metal heads here has anyone made this mode to see if it actually will work?My thought for at least the front side of the case, if someone with access to a burning table and machining capabilities could make a girdle to bolt on over the caps for the shafts. Should be fairly simple to make and install as well as quite marketableView attachment 804628View attachment 804627.
It's been done and I think there were pictures of it on this forum. It's been many beers since I saw the pics so I have no clue where the write-up is stashed or who did it. Seems like it would be an item with a decent demand within this group.Has this ever been done? All of us metal heads here has anyone made this mode to see if it actually will work?
Not since I joined. I haven’t had access to the equipment to do it since before I bought my truck.Has this ever been done? All of us metal heads here has anyone made this mode to see if it actually will work?
