Battery chargers
jcollings
391
Jupiter/FL
I have several battery chargers that I've used.
NOCO Genius 2600,
Batteryminder 24 volt,
Batteryminder 12 volt,
and Charging charger 10 amp 12 and 24 volt.
opinions on what works best including battery desulfator.
Thank you,
Scar59
41
Mt. Eden, KY
I use the NOCO G2700 for 24v servicing. It has revived several old batteries. fabricating a NATO plug adapter for it.
jcollings
391
Jupiter/FL
Yes I made one of those NATO connectors has about a 60-foot reach then made a square box with a couple of terminal post on their works pretty good
jcollings
391
Jupiter/FL
I did have a problem with the Noco 2600 boiling a battery over after leaving it on for some time that's why I purchase the charging charger which does not go over 14.9 volts ever to prevent that from happening. Although the Noco does a good job if you keep track of it, I just don't want to destroy another Hawker.
Scar59
41
Mt. Eden, KY
Actually, I have the G7200, mis-typed it, It has never had an issue, 12v or 24v. Fabing up a NATO plug adapter.
