therooster2001
- 44
- 28
- Colorado
I will start at the end, then jump back to the beginning of the issue. I was leaving for the night and hooked up my NOCO charger to the slave port, and after a couple of seconds, it goes into an error state. 1 blinking LED, which the manual indicates that the battery can't take a charge. I measured and I am at 25.x volts at the slave port and at the battery (not suspecting the slave port or cables). I did have an odd start to the truck that day. Master on, then go to run, and I heard the CTIS GPU hiss oddly and the ABS click, so I shut it off quick, then turned back on with no issues and no problems during the run, volt meter in the green etc. I doubted the charger, so hooked up to the car, and it is just fine. Before this, I had no issues, it was all in the green every time, and while I didn't check when I disconnected it to start it, I'm pretty sure it was not in alarm. I don't know what it is sensing that makes it go into alarm. Anyone had experience with that?
Since it's on my 5 ton, I posed this in the 5 ton forum, but if it needs to be moved, have at it...
