Be careful with jacks
gtsig
Rustburg Va
Should we go around and take their bottle jacks:twisted:
Everyone be careful because we want to see and talk to you tomorrow again. Use common cents and think what can go wrong (it will). Better to take 5 mins an hour and be safe then lose an arm leg or life.
98taco3
Berthoud, Colorado
as someone who has been hurt on the job by a failing hydraulic jack, i give my warning. Never use just a jack to support ANYTHING heavier than a few pounds. 2 years ago i got hurt at work by old and worn out lifting equipment. I was replacing a loadshaft on a tractor when it happened. The drawbar frame is what did it and probably weighed in the hundreds of pounds. Absentmindedly i stuck my finger in the hole to check alignment because the pin would not fit. As i did so, the jack collapsed shearing the end of my finger off in the transmission. Always take care, getting hurt really really really sucks! And remember, dont stick your fingers where you would stick your pecker! :mrgreen:
and for some shock value to complete my point.....
