EveOfDestructionDeuce
- 0
- 0
- Dortmund/Germany
Are the all steel head gaskets, better than the thicker/newer composite gaskets?
Are these cooper gaskets from the same folks making Cooper tires?
This is why it is imperative to stick the oil and look at the coolant on EVERY cold start.head gasket fail is the cause of most engine fail of the multi fuel. If you have been around the mulit for any time you will know/find this out.
