Elektroman99
- 137
- 43
- Siegburg, Germany
Dear Steel Soldier Community,
I'm hoping that the forum's wealth of knowledge will enable me to avoid one of the steps.
First of all, an explanation:
I would like to install a second sensor to determine the temperature of the cooling water in addition to the "factory-installed" cooling water sensor in the radiator.
I know that the radiator has one or two blind plugs on the left-hand side when viewed from the front. It has to be said that I assume it is the original radiator fitted at the factory.
I just want to avoid draining and refilling the cooling water before fitting the second sensor, hence the question here in the forum.
Does anyone here in the forum have an empty original radiator or a vehicle in assembly in which there is no coolant and can tell me the thread size and standard of these "dummy plugs"? If anyone knows the place in the technical information and manuals where these are named, please let me know (name of the document and page).
I would be very pleased to receive your answers or references to further information.
Best regards
Elektroman99
Best regards
Elektroman99
