2mtrucks
- 1
- 6
- col. city in
I installed a block heater Friday (from NAPA PN Kat30101)...quite easy to do. I used the forward inspection cover because its easiest to get to. It took far longer to drain and refill than install. I did let it sit overnight since the brand I installed recommends both a gasket and sealant. Plugged it in for two hours this morning and it fired like it was 80 degrees outside. I have a working ether system but I would prefer to start it this way. I have had several older tractors and trucks that had to be started with ether and I understand these old Cummins were designed to start that way but I would rather start a warm motor if I have the choice.
