86m1028
- 17
- 38
- Murphy TEXAS
congrats on the new truck !We are the proud new owners of one bad ass, sweet driving old truck! Guy let me drive around his field in 4 low to test it out. So tough
I've got the disease for sure. Named it the Rogue Sea Witch!I'm not sure if you affected me Drunkle or not, but I just picked up a M1010 today. LOL See this is a very infectious disease that spreads rapidly!
Yeah I may still go with ac in the cab. It gets hot in there in the sun. I think I'll keep modifications to a minimum for reliability sake, aside from the camper build. I would like to do a long leaf add a leaf and replace the worn out shocks/ steering stabilizer with heavy duty bilsteins. Hopefully that will fit 255/85r16E Toyo M55 tires. I'll probably get a Detroit locker for the rear as it has been removed from this truck. Dual fuel tanks, maybe a fresh water tank where the spare is and relocate the spare to a swing away bumper mount. Eventually I'd like a small fridge, small stove top, solar charging for maybe two deep cycle batteries with a battery isolator that charges the primary batteries first then the rv batteries. Fold away bed and table and seats\bench for 4 with seat belts. Everything in the camper would be able to fold up to the sides when not in use to keep the space available for hauling. I'd like to tig weld aluminum frames for all these items to keep weight down. Use milsurp cargo net bolted to the frame for a bed, with a futon style pad on it. I'd love to eventually add an ORD Magnum box with np205 for added low range... but we'll see how far we get along. First is some basic maintenance.I'm glad you picked this up, seems like you are enjoying the new ride!
You can use your existing A/C compressor for onboard air if you fix the clutch. You just need an inline oiler and dryer. Remember, if you want A/C in the cab like we discussed, the hard work is already done. You have a compressor mounted on the engine.
Any big plans for modifications?
