Bracket Question
Oilleaker1
Crook City SD
I asked the same question. Does your cab have the reinforced rivited on rear panel inside the cab? Mine did. I also found links down inside the right cowl vent at the bottom. I also found links and 50 cal. brass in front of the battery box. That makes it no doubt that it had a gun ring on it at one time. Maybe the cracked RH windshield was from loud noises huh?8) John
