Brake adjustment after replacing wheel cylinder?
yolner
68
Rockville, MD
I just removed the wheels still attached to the hub/drum on my rear axle to replace the seals and the wheel cylinder. I didn't touch the adjusters when removing the wheel cylinder.
My question is do I need to do the major brake adjustment if I'm replacing the cylinder and reusing the old pads? Since the wheels are still on the hub I can't use a feeler gauge and would have to do it by feel.
1,132
TM says major adjustment when you replace shoes, minor for servicing.
Major = mess with bottom anchor
Minor = only mess with upper pivot
Pads = disc brakes
Shoes = drum brakes
:D
rosco
30
Delta Junction, Alaska
Most Folks, don't adjust their brakes, often enough! When they are adjusted properly, its usually tough to get the drum off, without backing the shoes off.
