Brake bleed alone.
Floridianson
2,514
Interlachen Fl.
Not lucky enough or maybe unlucky enough to have a mate here at the house. So off to the ACE hardware to get one gallon sprayer., Had the 5/16 hose here and had to buy the fitting. 1/8 NPT to 5/16 hose barb. I unscrew the adjustable tip on the sprayer. The 5/16 hose will fit over what threads are left after you remove the tip. I did put a hose clamp there just incase as this dot 5 is not cheap and will put one on the brass fitting. I just undid my whole stock fitting from the master cylinder and screwed in my 1/8 NPT fitting into the master. Ready to bleed.
