- 1,925
- 30
- 48
- Irmo, South Carolina
I recently discovered there is a retro-fit fix for the deuce brake light switch, eliminating the hydraulic switch and replacing it with an air activated switch. I think I saw it on Erick's or Saturn Surplus...... I once had a brake light pressure switch fail and start leaking about 3 miles from home base. I had to use down shifting and the hand (e) brake to nurse the vehicle slowly home (and I had relatively flat terrain). Now that was sketchy and really increases the pucker factor! .....
Rick
