MyAngry85
- 0
- 0
- Chicago/ Illinois
Having brake issues on my 87 1008. It started with the brake peddal going to the floor with ease only after start up and then fine. I checked for leaks, found brake booster leaking, changed booster, problem continued. Changed master cylinder after finding it leaking from weap hole, used a new Napa master, bench bled per instructions using supplied caps not hose fittings. Bled brakes with one man bleeder. Now peddal loses pressure randomly while driving. Now I decided to bleed with a power bleeder, I'm getting a constant flow of tiny bubbles spaced about an inch or so apart. I bled through mutiple 12 oz. containers of fluid. I then remembered you're supposed to compress the button on the combination valve. I checked the button and it basically seems compressed, I just get a hair of movement. Any thoughts on whats going on here?
Thanks for any comments!
