Brake light issue. At a loss
springbok
Wilmington Delaware
I am having an issue with my drivers side brake light. The right one works fine but the left one is very dim. I replaced the light switch to start. No luck. I tried 3 different LED tail lights. Same thing. Turn signal works fine. Hazard light works fine. Just the brake light. I tested the trailer plug and plug B (left brake light) looked to have 24v. Any ideas???
springbok
Wilmington Delaware
Only getting 6V at the light when I hit the brake(only on left side). Turn signal works fine. I changed the turn signal switch. Nothing. Jumped the brake switch. Nothing. Any ideas.
Coffey1
497
Gray Court SC
What voltage before the light.
See if your losing the volts before the light or in the light.
springbok
Wilmington Delaware
After checking the trailer plug I get 6v there also. Was dark last night so my mistake. I am really at a loss I guess I have to trace it all the way back to the turn signal switch
NDT
6,432
Camp Wood/LC, TX
The same 461 wire goes to the turn signal control that powers the same bulb for brake and turn.
springbok
Wilmington Delaware
Fixed. Seems that the turn signal lever was bad and to make the newer type of lever to work you have to remove the bulb and put in an LED one. Ahhhhhh thanks for everyone's help.
