77 M880, lights turn signals work. Emerg. flashers do not work.
Brake lights did not work. have hot feed to brakelight switch, but white wire running to back showed it was shorted with tester.
Ran new wire from the switch to back wiring harness and tied it in to the 2 yell/stripe wires and presto, have brake lights.
Problem; when I turn on left turn signal with the brake lights on, the signal does not work. Left signal works fine with headlights and all other times, just when you press on the brake pedal.
Any idea's??
Did I hook the new brake light wire to the wrong wires in the rear?
Thanks in advance.
Any idea's??
Thanks in advance.
