Francis89
- 9
- 3
- Washington
Ok so I’ve scoured the threads a while and haven’t found anything relating to my issue. I bought a bobbed deuce a little while back and have had quite a few issues. I’m working them back to get this truck safer to drive.
So the issue is my brake lights. I don’t have the pressure or the air switch. I have a switch mounted under the brake pedal. I’ve adjusted it to where it turns the lights on with the slightest of braking pressure. That’s where they work. Once I start the truck up about a minute later the brake lights don’t work. I don’t have turn signal wires going back but the night time running lights still work. For some reason they just stop working after I turn the truck on. I’ve tried moving the light light switch to all the positions and it’s the same. They work fine with the engine off.
Thanks guys
Thanks guys
