First, please go easy on me for not searching. I was not able to find a brake thread that quite explained what I am experiencing with the brakes on my Deuce and I definitely want to get this right. As much as driving the truck brings a smile to my face... sometimes the brakes nearly scare the **** out of me!
1. At the first press of the brake pedal while driving or with the engine running, the pedal goes nearly to the floor. It does brake somewhat but the pedal travel is extreme and the brakes do not apply until the very end of the pedal travel.
2. If I release the pedal and immediately reapply the brakes, they seem to work normally. Not sure what normal really is since this is my first time driving a Deuce.
3. However, sometimes if I press and reapply the pedal it will be very hard as opposed to being very soft. This is kind of scary because I have almost no brakes when it decides to do this. If I have the state of mind to release the pedal and reapply sometimes they will start working again.
4. If it matters to the problem, the handbrake is adjusted all the way tight and does not work at all.
I am thinking this could be an air pack problem but its seems that this is one part that is kind of expensive to be guessing with. Is there a test procedure to troubleshoot this and where do I find it?
