Broken glow removal,Any advice ??
jcappeljr
27
Delta, PA.
I am replacing glow plugs in another hmmwv I bought.I have a glow plug removal tool,I got all the glow plugs out.But the last on on the drivers side,all the way back near the firewall broke off after it came unscrewed.Its swelled up and wont come out.I removed the injector but still cant get it.I am afraid to push it in and not be able to get it from the injector hole.Not much room.I am installing Kascar non sweling glow plugs.Any help would be appreciated.thanks.
gem1410
44
TOMS RIVER NJ 08527
Get a nut that fits the glow plug threads--cut the nut in half--place the 2 pieces around the thread of the stuck glow plug--put a wrench on the 2 pieces to hold it together--screw the glow plug out--this will force the nut against the head and the plug pulls out====spray the plug down with penetrating oil first--had to do 6 this way---If only the tip is left of the injector I would call Dennis at Kascar--He has great info on difficult projects--good luck John
rchalmers3
30
Irmo, South Carolina
If it sticks up any and it's steel, you may be able to weld a nut onto the tip for leverage and turning.
I would start soaking the hole with penetrant as well.
Rick
Flingarrows
N Central Illinois
I bought a pair of angled forceps and used that to pull 6 of 8 swollen glow plugs through the injector hole. I just broke them off, since I don't have the tool. . With the injector out, you can stick your finger in and feel the gp tip. I couldn't fit the forceps and finger in at the same time, but after pulling the 2nd, the others went fast, because you get a technique down
Flingarrows
N Central Illinois
The forceps work good because they are slim, and have a locking mechanism to keep hold of the broken tip once you get a good grip on it. I got an angled pair on eBay for under $10. The hard part was waiting for them to get delivered...
I put a piece of blue paper towel to keep partials from dropping into the combustion chamber. Once you do one, you will be surprised how easy it is. It took me 20 minutes for the first one. After the first, I can get them out in under 10 minutes. Then hit the injector hole with a thin nozzle from a shop vac, to pick up any debris
1,178
It does if you don't get it stuck(or broken off) in the hole first.
I've done it many times. I use vice grips on it and push it in as hard as possible. The combustion pops it out and I push it in, after a few repetitions, it will come out. You can rev it up a little to help this process.
1,178
Yes, but I only do this with a whole GP(not a broken one).
Gloves, glasses, and hold on tight.
Picture pushing in like the vicegrips are a screwdriver handle. Push in as hard as you can(you can't overpower the combustion).
This is like knocking it out with an impact punch, from the inside.
Flingarrows
N Central Illinois
I missed the "push it in" step, and just unthreaded, and fired it up. Good info
1,178
Yeah, you need to push it in like you are really trying to hold it seated against the head. You can't, so it will pop out with every fire, and usually in about 5 seconds it comes out.
A little engine heat, and rev(2500ish) works well.
Retiredwarhorses
4,174
Brentwood, Calif
The glow plug is in the pre-chamber, if it breaks of its still in the the prechamber, remove the glow plug and stuff cotton in the injector hole, push the broken piece in and use a magnettic pickup probe or one of those flexible claw pick up things....not sure what they are called, I use it all the time when I drop stuff into strange areas that have no access...except for where the stuff dropped into....you push on the end and the 4 claws spread out the more you push on the end...they are flexible and about 18in in length.
the cotton prevents any from entering the cyl and is easy to fish put.
jcappeljr
27
Delta, PA.
I tried that ,The tip is too long.When you push it in it hits the back of the head.It wont drop down.I guess I will try putting the injector back in and starting it and see if it blows out of the glow plug hole.Will it start with 7 glow plugs.
dilvoy
25
San Francisco, Ca.
I found by saving many swollen glow plugs over the years and then finaly testing to see on a removed head, if a swollen tip would pass through the hole of the pre chamber into the cumbustion chamber, that they won't fit through. If the tip is broken and jammed into the threads, you need to pound it back so it falls into the pre chamber then grab it out of there through the injector hole. If you are worried about doing that, then you can just leave it jammed there and run on seven glow plugs or pull he head and send it to a shop.
