Feltz and the war surplus guy in bells, TXLet's approach from another direction. What rims will the 12.00 fit in dual configuration and have the necessary space between them without a spacer?. I am willing to make an adaptor, but have bolt clearance problems going to a 5 ton rim that will cause a problem.
What is the dual rim that has 13.19 bolt circle? I think there are aluminum ones.
Edit... I think a dually MRAP budd is it. Who would have those surplus?
I would not try it if not a 4x4 and space for 395s.....bed an m105. But plan was to flip hubs to the inside and run dish out A3 wheel, where this mod keeps the hub in its outer position. Spare can still be an A3 wheel with 395.If you can stuff the 12.00 duals in there, I definitely want to see a picture! It will look massive! A truck that means business!![]()
