tco3129
- 4
- 0
- Flat Top W.V.
Dodging snow and rain, I finally got my LDT torn down. I knew I had lost a cylinder liner and piston, a relatively easy fix, but was concerned when draining the oil when I got 4 gallons of antifreeze first out of the oil pan. I had checked the heads first with the blacklite and spray and found no problems. Had to pull the oil pump to get to the rod bolts on #1 piston. Once the piston was out I wiped the cylinder with a rag and WELL CRAP. Block busted right behind the front freeze plug. This is the second cylinder liner to go to the oil pan. #4 went December 2013. #1 went December 2014. Now my question. Is loosing liners and pistons common? I run Rotella oil and fresh antifreeze. No overheating problems. Next can the block from an LDS be used for an LDT?
