gimpyrobb
dumpsterlandingfromorbit!
- 27,785
- 748
- 113
- Cincy Ohio
Those appear to be remove able, but aren't when you look close.Mine is a bolt in but it doesn't look like that. More like a piece of channel iron flipped on its back.
Interesting. I will need to inspect closer.Those appear to be remove able, but aren't when you look close.
I'm assuming your speaking of the rivets that go through the bottom of the hangers and through the bottom of the frame?Look real close at the spring hanger area.
It can be done, you just have to remove the rivets and install grade 8 bolts. Of course that was easier said then done !So has anyone swapped cross members from the riveted type to the removable type yet? It doesn't look too hard to do but I haven't really inspected both setups real closely to be fair.
