Looks different than mineSame thing here.. I have an A1R (so it is a fixed cab.. no air or adjustments).
If this is in the TM, I can't find it.
I guess just cut one out of horse stall mat as well? If there is a replacement/part#, please share.
-Gavin
You need an additional set of the cab support bushings - the A1R stack up uses the same bushings as the front of the cab. I had new one's made by one of the original manufacturers. I have sets for sale. $175 shipped per set. A1R needs two sets and you'll end up with one spare thick bushing. With that bushing failure you have going on there - watch out that the cab doesn't short out on the ether solenoid, or the alternator studs, etc. Very dangerous to have it floating and not secured like that.Same thing here.. I have an A1R (so it is a fixed cab.. no air or adjustments).
-Gavin
How old are they? They have a hard and fast shelf life due to their construction. They will turn soft and gummy. If you can press your fingernail into the material and it leaves a permanent imprint they are trash. I see "new old stock" one's being sold that are absolutely trash.Well.. Good news.. I already have two 5342-01-371-793 (part #7 above). These are on the shelf waiting to be installed in the front (both of the fronts are dust).
they are NOS.. expiration date of 2019, but the rubber still feels good.. not squishy or gummy.How old are they? They have a hard and fast shelf life due to their construction. They will turn soft and gummy. If you can press your fingernail into the material and it leaves a permanent imprint they are trash. I see "new old stock" one's being sold that are absolutely trash.
And others that are made from Urethane don't have the correct material properties. They were vulcanized rubber for a reason.
Might be ok for a short time. They have an expiration for good reasons. I wouldn't bother with them personally. That means they were made in 2009 most likely. Like old tires they will disintegrate surprisingly quickly once they start seeing use and flex, etc. Gotta love the surplus scalpers selling expired garbage.....they are NOS.. expiration date of 2019, but the rubber still feels good.. not squishy or gummy.
I'll keep my eye on it.. got a lot of other things on the 'to-do' list for the truck...Might be ok for a short time. They have an expiration for good reasons. I wouldn't bother with them personally. That means they were made in 2009 most likely. Like old tires they will disintegrate surprisingly quickly once they start seeing use and flex, etc. Gotta love the surplus scalpers selling expired garbage.....
I second on not having to do the driver side mount more than once. What a pain in the behindI'll keep my eye on it.. got a lot of other things on the 'to-do' list for the truck...
i am interested in your mounts though.. i'd much rather do the driver front cab mount once.
Passenger side and cab latch mounts are easy
Broke a 1/2" extension doing mine. Breaker bar and a cheater pipe and some swearing. Fortunately my truck was a Kuwait/TX stationed truck and a 2008 so most of my problems are related to mud dobbers and the two dust bowls she lives in. Very little actual rust. I pity the guy that has an A0 Hawaii truck and has to do those bushings. Honestly once the nut busted loose the rest was easy though.I second on not having to do the driver side mount more than once. What a pain in the behind
I too broke a half inch extension and breaker bar. air impact would not touch it, nor would 2 electric/battery operated. I tried 3/4 but my impact socket was too thick and i didnt have an extension. so bought an extension borrowed a socket from work and sprayed in kroil for 24hrs and somehow came off easily the next day. getting my hand in there to get the nut started was a 3 hour ordeal.finally used vise grips to hold the top down while i got the nut started. so an extra set of hands would be very helpful for that partBroke a 1/2" extension doing mine. Breaker bar and a cheater pipe and some swearing. Fortunately my truck was a Kuwait/TX stationed truck and a 2008 so most of my problems are related to mud dobbers and the two dust bowls she lives in. Very little actual rust. I pity the guy that has an A0 Hawaii truck and has to do those bushings. Honestly once the nut busted loose the rest was easy though.
