dezert ratt
- 12
- 16
- menifee, ca
I installed my rears dish out (24 bolt aluminum mrap) and I had clearance issues with the brake drum nuts and the 24 rim bolts. I clocked the rims to a different hole on the wheel studs and repeated until the nuts on the rim and the nuts on the brake drum cleared each other. If you run dish out make sure the nuts are not contacting each other, that can cause major damage when the lugs get torqued. Another thing, the valve stems are now facing the brake drum and are now no longer accessible. I fixed this by drilling and tapping the dish side of the rim for 1/4 " valve stems. The aluminum wheels are thick enough to tap adequate threads.
