- 10,859
- 746
- 113
- Front Royal, VA
Folding jacks are garbage, always have been. The reason they are there in your truck is because they are so cheap to make, heck they are folded sheet metal put together. I've had a couple of them bend and break apart under normal loads.
Get either an 8-ton bottle jack (you can use it for the deuce as well) and some 10x10 oak blocks that truckers use for cribbing and chock blocks. I also highly recommend a REAL Hi-Lift jack, not one of the cheapo wannabes. If you know how to use it, it will pay for itself within a year. I've been off-roading for 20 years and the Hi-Lift hasn't changed much, IT DOESN'T NEED TO BE.
