jrobinson5093
- 0
- 16
- jakin georgia
I just changed all three fuel filters on my m35a2 now it dont seem to have half the power that it did and no smoke at all. it was smokin pretty good. Does any one no the reason for this?
Are you still running straight WMO?I just changed all three fuel filters on my m35a2 now it dont seem to have half the power that it did and no smoke at all. it was smokin pretty good. Does any one no the reason for this?
lI dont think its the fuel i had the same fuel in it before i changed them and it run fine, it just started cuttin out under heavy throttle in high gear. the truck had a filters made of wound sting as the secondary filters and a paper element for the primarly. the ones i put in were all paper would that have any thing to do with it. the were wix brand part numbers 33511 for the primary and 33512 for the other two now i have to put a flat washer on top of the spring in the primary to hold the filter up because the hole in the bottom of the filter was larger than the one i took out. the truck does not sputter or any thing it runs smooth it just has way lil power.
i have a few concerns first if your getting more power that is not a symptom of clogged filters. more power and smoke would be a result of more fuel being introduced to the enginethe truck always had good power but a few weeks ago it started to have a lot more power and smoke and a few people on here to me it was my filters clogging up. it did fine until yesterday it started starvin for fuel in high gear i changed the filters and now very lil power.
jrobinson now i have to put a flat washer on top of the spring in the primary to hold the filter up because the hole in the bottom of the filter was [/QUOTE said:Something don't sound right there. The filters in order are washer spring washer O ring and the brass looking cup with cup faceing up to seal the filter.
I always recomend change out all filters before you run these machines. to many have had the filters installed wrong or with missing parts.
Has your FDC been bypassed.
