King
- 0
- 6
- Tulsa Oklahoma
Hey neighbor, after you are settled, lets have a cold beverage to celebrate the iron sickness we both suffer
Old Bust Head Brewery is just up the street.....
How does your torque coverter unlock feel when slowing down? I've read that their unwillingness to unlock was a huge problem in the military, killing lots of soldiers. Not sure if any MWO's addressed that or not. But all of our trucks you can absolutely feel the harsh torque converter unlocking event except for in the truck that has ATF for trans fluid. The rest all have motor oil. They claimed the ATF was supposed to help soften up the unlocking and downshifts and based off this truck, I'd say they were right.Congrats!
Trans should be butter smooth shifting up and down. Lube the modulator cable. Adjust it if necessary. You can have a full cup of water on the floor of my truck with an open lid, and it will not spill on any downshift, all the way from 67mph to zero. I'll post a pic of where the adjustment is set at on my modulator cable.
Mine feels good, stock oil, don’t feel anything. The torque converter could not unlock fast enough on a hard brake where wheels would slide. Engine stall, loss of steering assist, truck goes sideways and rolls over. Fix was to add ABS to all the trucks which cured this issue.How does your torque coverter unlock feel when slowing down? I've read that their unwillingness to unlock was a huge problem in the military, killing lots of soldiers. Not sure if any MWO's addressed that or not. But all of our trucks you can absolutely feel the harsh torque converter unlocking event except for in the truck that has ATF for trans fluid. The rest all have motor oil. They claimed the ATF was supposed to help soften up the unlocking and downshifts and based off this truck, I'd say they were right.
That's right. I couldn't remember how the ABS upgrade factored into that story. Funny enough my USMC truck doesn't have ABS. I'm wondering if I should be scared or not. Guess I'll try the cable lube on the other trucks. Got a preferred lube?Mine feels good, stock oil, don’t feel anything. The torque converter could not unlock fast enough on a hard brake where wheels would slide. Engine stall, loss of steering assist, truck goes sideways and rolls over. Fix was to add ABS to all the trucks which cured this issue.
No USMC/Navy 939s got it. Salt water and electrical components aren't compatible.That's right. I couldn't remember how the ABS upgrade factored into that story. Funny enough my USMC truck doesn't have ABS. I'm wondering if I should be scared or not. Guess I'll try the cable lube on the other trucks. Got a preferred lube?
Was reading that possibly the Navy Seabees got it. But I haven't found anyone who's scored one of their trucks.No USMC/Navy 939s got it. Salt water and electrical components aren't compatible.
I ran without ABS for years. Only locked em up once.
They have an alcohol evaporator mounted to the block on the driver's side. So air dryers aren't needed.Was reading that possibly the Navy Seabees got it. But I haven't found anyone who's scored one of their trucks.
I'm noticing the USMC without ABS also doesn't have the Haldex dryer. Not sure if that's a good or bad thing for the rest of the system. It's obviously one less thing to maintain though.
