nf6x
Feral Engineer
- 1,630
- 50
- 48
- Riverside, CA, USA
One of my tasks for this weekend is draining my wrecker's hydraulic fluid, servicing the filter, putting it back together and refilling the fluid. I'm reusing the old fluid, but I'm pumping it through a spin-on hydraulic fluid filter on the way back in, then adding more to top it up. I'll probably need to get more fluid; it was already 5 gallons low, I expect to lose some fluid in the process, and my local industrial supply place just had one bucket of ISO 46 / SAE 10 fluid on hand.
Here are some pictures of the work in progress. The filter appears to have a reusable wire mesh screen that I should be able to clean up and reinstall.
Harbor Freight sells some handy items, like the magnetic paper towel holder and magnetic disposable glove box holder shown here.
I'll take some pictures of my drum pump setup when I refill the fluid.
There's a drain plug hiding on the bottom of the hydraulic fluid tank that I was hoping to remove in order to get out some of the scum that I assume is on the bottom of the tank, but it didn't want to come out even with a 1/2" drive air impact wrench.
By draining the tank before removing the filter, not too much fluid came out.
