- 3,227
- 3,277
- 113
- NORTH (Canada)
Situation: engine out, cribbed on blocks of 6x6 on my trailer (so I can work on it and move it; I have no lifting devices).
I have approximately 10 inches of clearance underneath the "deep" hump of the oil pan (about the depth of the sump). Before I lay down inside the trailer, spoon with the LDS, and make a mess (with oil!), is that enough clearance to drop the pan and pull it out? I have enough room on the sides.
I **can** jack the engine higher, but try to only lift it up as high as necessary. And, safety first, the engine will be strapped down with two ratchet straps to prevent shifting or tilting.
