Command Cars of Fieldmarschal Erwin Rommel
CARNAC
The Envelope Please.
620
Corpus Christi, TX
What's with the drop at the front of the antenna?
Seen another rubber-tired WWI German APV somewhere with a similar down-turned antenna:
- Any HAMS or radioheads here to explain that?
And there was another halftrack with similar antenna but bigger. It was the SdKfz-251/3. The French Panhard armored car was also equipped in some cases with a frame antenna. There was also a 6 wheel version of the SdKfz232. It was very similar to the 8 wheel version.
CARNAC
620
Corpus Christi, TX
I think the droop at the front was for brush rather than a signals function 'thing' but I could be wrong on that. In the case of the halftracks, the array could be lowered but it wasn't like a pop pop I'm it's up or down. I think it was a little more involved of an issue than that.
Another Ahab
4,455
Alexandria, VA
I'm going to go fishing in the Radio forum for a response about this, and see if anybody pipes up with an answer.
Another Ahab
4,455
Alexandria, VA
Horch 901 Kfz.15
Another of Rommel's various Command vehicles:
- apparently 4x4, but can't confirm if that's full-time or through a transfer case
- not sure what the canisters on the fenders are about
- link below has an album of features
And as noted in the center photo, sometimes even a Generalfeldmarschal has car trouble:
http://youtu.be/ZX2Sjno4L7g
Another Ahab
4,455
Alexandria, VA
I saw a reference somewhere (or at least I think I did), about a Horch 901 Kfz.16 "Heavy Field Car":
- But no photo record I can find to back it up
So this pretty much wraps up the story of Generalfeldmarschal Erwin Johannes Eugen Rommel and all his Afrikakorps Command Cars.
Please have at it, if you got more to add. The End.
