brasco
- 1
- 16
- Southeast of Indianapolis, In
So, why do you say that?The XL tire may blow out at any time without warning.
edit: So if you run some XL tires its better to have them on the rear only and use goodyears or XZL on the front.
IIRC, that was a common occurrence with the XLs used on the M35A3s, mainly because they had a habit of sitting flat for too long and damaging the sidewall. Never heard of that with the M939A1s that the big XLs came on.So, why do you say that?
I personally have had good service from:So...which is better? The Goodyear A2s or the XZLs...? Hmmm... I have read several threads but no real strong opinions (or data) that I can see.
It was more of a rhetorical question.IIRC, that was a common occurrence with the XLs used on the M35A3s, mainly because they had a habit of sitting flat for too long and damaging the sidewall. Never heard of that with the M939A1s that the big XLs came on.
http://www.steelsoldiers.com/showth...-Fort-Hood-Have-a-few-general-questions/page3So...which is better? The Goodyear A2s or the XZLs...? Hmmm... I have read several threads but no real strong opinions (or data) that I can see.
Post 27. I'd personally go with the ZXL's if you were going to buy new tires, they look meaner and are plenty-full since they usually come new on MRAP rims.
TIRES: 14.00 Michelin tires are rated for 55mphs. Now two of my tires were brand new. Another two were clean just older and the last is good on tread of has cracking on the sidewall. That was my spare. 300miles into my 950 miles trip I had a blowout on my front driver tire. One of the older clean tires. Up to that point I was pushing the truck to 60-65mphs and making good time. The coolant I used inside the tires was steaming out and the rubber was very hot. I was lucky I only lost one tire and that the tire started to thump before it went so I could slow down before she finally went.
