Cranetruck tire bead breaker
cranetruck
75
Meadows of Dan, Virginia
Went to a local tire shop for more info and they use a liquid soap on the bead area before breaking it loose, sort of a soap "penetrent", since oil is not good to use on tires. The Tire Slick (image below) is also used for mounting the tire. I'll try this on next one...
armytruck63
10
Redlands, CA
Years ago my dad and I had to remove some fossilized tires from some WWII jeep split rim wheels. Since the tires were trash, we lined up our M37 carefully and drove over the old jeep tires to break the bead. We turned the tires several times to get a new "bite" before the bead let loose all the way around.
pittdog
Black Creek , NC
hey cranetruck !!! Leme tell you how we did it in the 70's... Broke the split ring.... Put dish soap round the rim... Took nother deuce rolled over the tire... Back up... Turn the tire... Do the same ... Over and over ! Bingo ! Broke it lose !!!... 52-d ret .usa ret !
