4x4e350
- 5
- 18
- Vestaburg, Mi.
I just aquired a "Mdl Uknw" crew cab from Gov. Liq., and have already recieved my "Paid In Full" invoice, so my recovery will have to be soon.
From all the searches I've done, from what I understand the crew cabs were just civilian trucks, basically painted green.
So does this meen they are 12 volt?
There are no front hooks attached to the frame from what I can see in the pics, so I don't think I can use a tow bar to get it home. Any trailer I have seen probably wont fit a crew cab, so I was wondering if putting the rear end on a car dolly may work. I've towed a full size car this way, which has the same width as a full size truck, so I think it would fit a larger car dolly.
It also says, "No Keys", so is there a trick to getting the lock cylinder out of the steering column, so I can use needle nose pliers to turn the ignition?
Any other information would be appreciated.
