paramilusmc
- 5
- 18
- Charlottesville, VA
Has anyone put a cruise control in there M1009 Blazer? Is it even a possibility with the 6.2 liter diesel? What do you guys think?
I have a 87 Sub with a 6.2 and cruise, I would imagine you would just need to find all the pieces from a yard, and you'd be good to go.Has anyone put a cruise control in there M1009 Blazer? Is it even a possibility with the 6.2 liter diesel? What do you guys think?
I don't know about the GM stuff, but I've installed cruise control in three Ford trucks and two Jeeps, all I needed for them was the cruise control box, the servo, speed sensor and the buttons on the steering wheel. For the 79 Bronco, I needed to pull the small harness to the control box, but it was a separate system from the main wiring harness.Junk yard takeoff would be a pain to install. I used a after market unit on another type truck that was easy to install and seemed to work well. Wayne
Generic aftermarket units are available. Had one on vehicle 10 years ago. Think it ran off a magnetic pickup added to the driveshaft or some such.Has anyone put a cruise control in there M1009 Blazer? Is it even a possibility with the 6.2 liter diesel? What do you guys think?
I would sure like to hear from someone that has done this to there CUCV.
