Jeffval
- 42
- 18
- Ramsay Montana
I just put new tires on my M35a3. The CTIS system was working fine. I aired up all the tires to 60 psi. I drove 6 miles and checked the air pressure in each tire. 5 of the tires, are reading 32 psi, but the front left tire is reading 60 psi. The CTIS is running its cycle but is not brining the tires up to 45 psi and the air pressure in the front left tire remains a constant 45 psi. And the CTIS control box will not shut off when I hit the off button. Does anybody have any idea what I should do? Thank you.
