RAJLMTV, how does that valve-looking part attach to the stem coming out of the wheel? Looks like o-ring seal? I have one wheel set up like that (all others have that valve parallel to the wheel, not perpendicular) and the joint is damaged beyond repair. It looks to have been jammed together with RTV, and was holding air until I removed it to change the tire.
Note that the stem is threaded internally but a Schrader valve will not fit (on mine anyway).
thanks,
Bob
