Aernan
- 19
- 18
- San Jose/California
My left rear tire is leaking down slowly over 2 days or so. I initially found a leak where the kneeling valve meets the valve stem for the tire. After disassembly re-assembly there I found the kneeling valve to be leaking. Cycling the valve seemed to only make things worse. Tonight I took it apart and cleaned the valve and no more leaks detected with soapy water. I used some WD40 and a bottle brush to clean out what looked like dark brown dirt or something. In two days we will see if I still have a slow leak.
Question:
In the TM 9-2320-365-24P Figure 158 I see what looks like a schrader valve in the valve stem. I have not taken apart any more wheels. Is this part optional or just missing on my vehicle?
Question:
