- 3,753
- 1,532
- 113
- North Carolina - FINALLY !
I was referring to 1 Patriot, that's why I quoted his statement.All my accessories work,no i have another issue.
Borrowed the PPV from the 923, still nothing. No cycling, no lights. Did find Spicer CTIS troubleshooting PDF in another thread, I'm hoping the speed signal generator missing from this truck will turn out to be the culprit.If your PPV is stuck, you are not getting accesory air. Your gauges are only for the primary and secondary braking systems. Need to free that up first before CTIS will see anything.
Can't find anything about the CTIS no lights in the TM's, but did find this in one of the threads http://dana.com/wps/wcm/connect/25f...=url&CACHEID=25f359804b1f69fba8acfff859534476Mine lights up with the headlamp switch. However, mine has an issue now, its not just lights turned off. It had worked flawlessly for 2 weeks. Yes i used mine a lot, mostly just playing around in back field and such,but it had worked great till just the other day. The little diag i have found seems to point to bad ground or controller. i will check wirinig, but im skeptical i will find anything.
Nope, no matter how long i hold the button, no cycling. I wish i had another(for more reasons than parts swapping. haha) one thing i have learned. with the truck running, if i unplug the big connector on the back of the controller when i plug it back in the mode light will come on briefly, as well as the oversped light, and then goes off. Another thing,if i would push the xc button,just to test it, then unplug and reseat connector, the xc light comes on and back off,if i then push the hwy button and then unplug and reseat, the hwy button briefly illuminates. i hope thats understandable.To me this tells me ive got good power and grounds and the controller is seeing and recognising something,but still not working. gotta be the controller. I will mess with mine a little more before i just source a used controller. I will report back asap. Thanks for the info.Same problem here. Only time I get any of the dots to light up is when I hold the button down. I get no cycling whatsoever. Yours cycle at all? I've got a couple other A2's so I might start substituting parts this weekend. Let me know if you figure it out before I do.
Don, mine turned out to be the PCU, Pneumatic Control Unit. Under the shield to the right of the shift tower. I swapped that out with a take off someone sold me and presto, everything started working. I do have to have the head lights or park lights on on to see the dots working on this electronic unit. None of my other ones need the lights on to see the dots. No Terrain Lights or DDM – Dashes "--" (Codes 51, 52, 54, 55, 56)Looks like I have a truck with the same issue... No lights unless I hold a button down.
Did anyone ever determine what causes this?
Thanks,
Don
So... I pulled the PMU out this weekend and measured the resistance on the pins per the troubleshooting manual. Two of the coils are are OK but the control coil reads open circuit. Also... it appears that this coil has been replaced sometime in the past (old one cut off and spliced in with crimp connectors). Perhaps something is causing this coil to go bad. Anybody seen this before?
I'm now looking for a new coil to replace the old one. Does anyone know where to get these? The numbers on the coil are 5C-4211-P7 on one line with MR 7 below it.
I searched online but no joy. Somebody has to have these coils in stock somewhere? Where did the army get them?
Thank for everyone's help. I should have the M931A2 up and going soon with or without CTIS.
Don
Yes. Once I put the new 5C-13-K24 coil in, everything worked just fine. The system started out with the flashing highwy light like it should. I ran the truck for about 1/2 hour and let the system do its thing. At first, I was concerned that the system wasn't working because it cycled several times before it really pumped the tires up. However, it settled into a long cycle and I eventually got a solid red light on the controller. I then measured pressure in all tires at 72 psi.So it worked then?
JC,Old post, old story. Same problem
Brasco is talking about PMU and 1 Patriot-of-many the PCU ???
Which one to check ?
Tks
JC
